After a long time of not using my table saw, and after moving, I wanted to cut two parts for a bathroom cabinet. I noticed that some sawdust had accumulated and jammed in the back, which the vacuum cleaner could not remove. I cleaned everything thoroughly. When I started the saw, it ran for two seconds and then stopped. Now it can no longer be switched on at all and you can only hear a hum.
I suspect that the start/stop switch is defective, but I don't want to just replace any parts. What is the best way to get started to identify the problem?
