#Author-
#Description-
import adsk.core, adsk.fusion, adsk.cam, os, traceback
def get_immediate_children(component):
# Get the child occurrences (components) directly under the specified component
child_occurrences = component.occurrences
# Extract the actual component objects from the occurrences
child_components = [occ.component for occ in child_occurrences if occ.isVisible]
return child_components
def _generateIteratedDataSet( inputDataSets, oneDataLine, iteratedData ):
index = len(oneDataLine)
if( index < len(inputDataSets) ):
inputDataSet = inputDataSets[index][1]
for data in inputDataSet:
oneDataLine.append( data )
oneDataLine.pop(index)
else:
tmp = oneDataLine.copy()
iteratedData.append(tmp)
def generateIteratedDataSet( inputDataSets ):
names = []
for inputDataSet in inputDataSets:
names.append( inputDataSet[0] )
interatedData=[]
_generateIteratedDataSet( inputDataSets, [], interatedData)
return( (names, interatedData) )
def verifyUserParameters(app, design, names):
ui = app.userInterface
userParameters = design.userParameters
for name in names:
userParameter = userParameters.itemByName(name)
if userParameter:
dummy = 1
else:
ui.messageBox('User-Parameter "{}" nicht gefunden.'.format(parameterName), 'Fehler')
return
def setUserParameters(app, design, names, data):
length = len(names)
for index in range(0, length, 1):
name = names[index]
val = data[index]
userParameter.expression = str(val)
# update parametric text plugin
app.fireCustomEvent('thomasa88_ParametricText_Ext_Update')
adsk.doEvents()
adsk.doEvents()
dummy = 1
def generateFileName( componentName, names, data ):
length = len(names)
text = ""
name = names[index]
val = data[index]
if( len(text) != 0 ):
text = text + "-"
text = text + name + "=" + str(val)
text = componentName + "-" + text
dummy = 1
return( text )
def exportStl( exportMgr, component, destFolder, fnBody ):
fn = os.path.join( destFolder, fnBody + '.stl')
stlOptions = exportMgr.createSTLExportOptions(component, fn)
stlOptions.sendToPrintUtility = False # Setze auf True, wenn du die Exportdatei direkt drucken möchtest
# Körper als STL exportieren
exportMgr.execute(stlOptions)
def run(context):
ui = None
try:
# Zugriff auf Fusion 360 UI
app = adsk.core.Application.get()
# Dokument und Design erhalten
product = app.activeProduct
design = adsk.fusion.Design.cast(product)
if not design:
ui.messageBox('Kein aktives Fusion 360 Design.', 'Fehler')
return
# Get the root component
root_component = design.rootComponent
# Get the immediate child components under the root component
immediate_children = get_immediate_children(root_component)
# change to your personal data here
inputData1 = (
("height", (10, 20)),
("width", (30, 40)),
("length", (50,60))
inputData2 = (
("MaleDiameterInner", (25, 32, 36, 40, 50)),
("FemaleDiameterInner", (25, 32, 36, 40, 50))
inputData = inputData1
destFolder = "D:\\tmp\\F360"
# end of personal data
iteratedDataSet = generateIteratedDataSet( inputData )
names = iteratedDataSet[0]
iteratedData = iteratedDataSet[1]
verifyUserParameters( app, design, names )
for data in iteratedData:
setUserParameters( app, design, names, data )
exportMgr = design.exportManager
for component in immediate_children:
fnBody = generateFileName( component.name, names, data )
dummy = 0
dummy=1
return
# dead old code below
# User-Parameter ändern
parameterName = 'HoseDiameterInner' # Name des zu ändernden Parameters
parameterObj = ui.inputBox("Bitte geben Sie den Namen des Parameters ein:", "Parameter Name", "HoseDiameterInner")
parameterName = parameterObj[0]
# Überprüfen, ob der Benutzer einen Namen eingegeben hat
if not parameterName:
ui.messageBox("Es wurde kein Parametername eingegeben.")
return
for parameterValue in [25, 32, 36]:
set_parameter(app, design, parameterName, parameterValue)
# Export
export_stl(exportMgr, component, parameterValue)
ui.messageBox('Export erfolgreich abgeschlossen.')
except:
if ui:
ui.messageBox('Fehler aufgetreten:\n{}'.format(traceback.format_exc()))
