Hello,
i'm very pleased that my former posts were helpful for you.
This machine is basycally a planing machine (?, = Abrichtdickenhobelmaschine) with a lot of
added features, in my opinion this is noticeable while working.
The planer is great! A VERY massive and solid construction.
On my machine is a 3,0 kW engine mounted which was a additional option; standard is 2kW.
But i think the 2kW is also a very powerful engine.
The saw makes not so much fun to work because the
fixed table is slim and the moveable table is not very easy to adjust exactly.
But cutting wood lengthwise works well because of the strong engine.
Another negative point is, thatyou can't turn the saw ->45 degrees.
You also have to remove all parts of the saw when you want the milling unit.
It always takes a few minutes, you can say that is no problem but for me it is annoying.
Addionally switching between the different funcions is not very comfortable because you have
to change the position of the transmission belt.
Between saw and planer it is no big problem, but for the milling it's not soo comfortable.
But otherwise the mill works nice.
The drilling unit is a nice feature and it works also nice, but i don't use it very often.
The table is not very big but ok.
So, what you have to mention generally is that 5 in 1 machines need a lot of space around them.
I do not have this, so i have to build the wagon to move the machine all the time.
This also takes time when you want to switch between the functions.
When you have several machines (planer, saw, mill,...) you can place some of them on a wall
and the space requirement of one machine is no so big.
But in my workshop the space is not enough for several machines so moving the 5 in 1 machine is necessary.
I hope this was helpful for you and my english is understandable..
Edit:
According to your question: the saw and the spindle of the mill are fixed in 90 degrees.
