Sandpaper
Status
Kate135
12. November 2023
ChinaZhengzhou
Sandpaper
Sandpaper is a paper with abrasive particles attached, used to smooth the surface of an object, or to remove attachments (such as old paint) from the surface of an object. It is also sometimes used to increase friction. Sandpaper is divided into different numbers according to different roughness to suit different uses.
1Basic introduction
Commonly known as sand skin. A material used for grinding.
Used to grind metal, wood and other surfaces to make them smooth and clean.
It is usually made of various abrasive grains glued on the base paper.
According to different abrasive materials, there are many kinds of emery paper, artificial emery paper, glass sandpaper and so on. Dry sanding paper (wood sandpaper) is used to polish the surface of wood and bamboo. Water-resistant sandpaper (water-resistant sandpaper) is used to polish the surface of metal or non-metal workpieces in water or oil.
All base paper is made from unbleached kraft wood pulp.
The paper is strong, wear-resistant and foldable, and has good water resistance.
It is made by adhering abrasive substances such as glass sand to the base paper with an adhesive such as gum and drying it.
2 Classification of sandpaper
Wood sandpaper, that is, dry sanding paper; water sandpaper, that is, water-resistant sandpaper; iron sandpaper, which is a type of dry sanding paper, is thicker and can polish the metal surface as quickly as possible.
In actual use, the classification of sandpaper is very inconsistent.
sponge sandpaper
Suitable for grinding smooth parts on various materials.
The sponge sandpaper sanding process has the characteristics of high production efficiency, good surface quality and low production cost. Therefore, it is widely used in furniture production. The final surface quality of furniture products is closely related to the sanding process. Sponge sandpaper is the main tool in the sanding process.
dry sanding paper
Dry sanding paper uses synthetic resin as a binder to bond silicon carbide abrasive to latex, and coats it with an antistatic coating to make a high-end product. It has the advantages of anti-clogging, anti-static, good softness, and high wear resistance. . Available in a variety of finenesses, suitable for sanding metal surfaces, putties and coatings. Dry sanding paper generally uses special kraft paper and latex paper, uses natural and synthetic resins as binders, and is manufactured through advanced high-static sand planting technology. This product has high grinding efficiency and is not easy to stick to chips, and is suitable for dry sanding. . Widely used in furniture, decoration and other industries, especially for rough grinding.
Water-sanded sandpaper
The texture is relatively fine, and water-sanded sandpaper is suitable for polishing things with fine textures, and is suitable for post-processing;
The gap between the sand grains of water-sanding sandpaper is small, and the grinding particles are also smaller. When used with water, the grinding particles will flow out with the water, so it must be used with water. If you use water-sanding paper for dry grinding, the particles will be broken. It will stay in the gaps between the sand grains, making the surface of the sandpaper dull and unable to achieve its original effect. Dry sandpaper is not that troublesome. The gaps between the sand grains are larger and the grinding debris is larger. During the grinding process, the powder will fall off due to the large gap, so it does not need to be used with water.
Its characteristics are:
1. Adopting linkage line production, the efficiency is high;
2. Since water-resistant sandpaper uses varnish as a binder, it takes a long time to dry, and its drying method generally uses hanging drying;
3. Water-resistant sandpaper generally has a finer grain size. The grain size of water-resistant sandpaper in my country starts from P80, and the fine grain size is connected with the grain size of metallographic sandpaper.
4. Water-resistant sandpaper is generally used for grinding under water-containing conditions, so there is less dust and good working conditions.
Water-resistant sandpaper can be called water-sanding or water-sanding paper. It is named because it can be immersed in water and polished during use. Durable sandpaper is named after durable water paper or polished in water. Durable sandpaper is based on water-resistant paper. It is an abrasive tool made of corundum or silicon carbide abrasives firmly bonded to the substrate using paint or resin as a binder. It has two shapes: page-shaped and roll-shaped. [1]
Dust-free mesh sandpaper
When using dust-free mesh sand to polish, the harm caused by the drift of harmful particles can be minimized. In 2013, whether it is a sanding disc or a sanding strip, Mirka dust-free mesh sand has a rich range of particle sizes for you to choose from to meet the needs of different sanding operations. Whether it is automobiles, yachts, engineering construction or even aircraft manufacturing, dust-free mesh sand is your best choice. In addition, the particle size range from P80 to P1000 can ensure that all your dust-free sanding operations can be completed in one go.
Compared with traditional grinding materials, there is no clogging. This feature greatly extends the service life of Abranet products; there are very few clumping, and efficient vacuuming fundamentally solves the problem of clumping; extremely high efficiency, greatly reducing The frequency of replacement of sand discs improves work efficiency.
agnoeo
14. Juni 2016
Rhein-Sieg
Persönlich finde ich das hier der falsche Ort für sowas. Zumal es English ist und dazu nicht sonderlich gut, z.B. „water-resistant sandpaper“ scheint kein gebräuchlicher Begriff zu sein. Was soll „sand-skin“ sein? Und inhaltlich ist es auch durchwachsen und tw von geringer Aussagekraft.
ymmv
Gruß, David
Hier wird so viel Dünnpfiff verzapft dass sich diese Thema sachlich eher positiv abhebt.
Wem das nicht gefällt der braucht das ja nicht zu lesen.
Mache ich bei ca. 80% der Threads hier auch nicht, bzw. schaue ich da nur ein einziges Mal hinein.
Wenn wir hier beurteilen wollen welcher Beitrag keine Frage stellt und auch keine beantwortet und daher weg kann wird es deutlich leerer werden im Forum.
Wie gut dass wir das nicht zu entscheiden haben.
Mich stört Kate135 nicht, was ich aber bei weitem nicht von jedem Beitrag der hier verzapft wird sagen kann.
Aber was solls.
Das Forum ist nicht mein Eigentum und ich habe die Freiheit etwas zu lesen oder das sein zu lassen.
Mitglied 67188
wenn ich eine monotone Aufzählung möchte über die Eigenschaften von Schleifpapier, schaue ich bei Wikipedia.
Absolut überflüssig.
Wenn noch mehr direkte Werbung aus China kommt und akzeptiert wird, werde ich mich hier verabschieden müssen.
Für mich ist das Werbung, Spam, KI Test.
... Führungskraft.. wer es nicht glaubt kommt auch in den Himmel.
Wolfgang EG
17. Oktober 2010
... Wenn noch mehr direkte Werbung aus China kommt und akzeptiert wird, werde ich mich hier verabschieden müssen. ...
Wer von so einem Schnulli seinen Verbleib im Forum anhängig macht, der scheint keine richtige Bindung an das Forum zu haben. Stell die Tante doch direkt auf Ignorieren, gut ist's ...
Wolfgang
PS: Habe ich etwas überlesen? War da irgendwo ein Link zu einer chinesischen Verkaufsseite drin? Dann sorry ...
Wolfgang EG
17. Oktober 2010
Ich nochmal: Wo fängt man an, wo hört man auf? Ich betreibe selbst ein Forum und weiß um die Schwere von Entscheidungen als Admin.
Aber wie soll das zukünftig dann gestaltet werden? Wie schon geschrieben, gehörten dann wesentlich mehr Eröffnungsbeiträge gelöscht. Also – so meine Meinung – locker bleiben.
Allerdings sollte mal geprüft werden, ob die Dame (?) unter Mehrfachaccounts unterwegs ist. Das wäre, denke ich, ein Grund für einen Rauswurf ...
Wolfgang
Mitglied 67188
ich habe Prinzipien und die sind bei China ganz klar umrissen.
Die Art der Bindung zum Forum kannst du gerne und ausschließlich meine Sache sein lassen..
und nochmal, wenn eine Führungskraft nicht weiß wie man Deepl bedient oder
keinen Ton der Menschlichkeit in Form von Hallo, Danke, Tschüß hervorbringt
dabei gleichzeitig in seinem Profil seine Firma angibt,
dann reduziere ich das ganze auf Werbung, Spam oder KI Test, wie gesagt.
Status
